lbrowne »
https://forums.nicoclub.com/lbrowne-u3597.html
Wed Aug 13, 2003 7:56 am
I know someone who has this device that you use for automotive like brake fluid and the like, you hook it up to the proper lines of what you want to make sure the air bubbles are out of, and itblasts the fluid through the lines....
Maybe I'll get a lend of this, but before I do....how can i check to see if the fluid is low that maybe just adding more brake fluid may help for the short term....
(I'm assuming theres a level it should be at in the master cylinder)
Thanks,
lbrowne
