grk nickafis wrote:I was in a safe open parking lot with my Z during a thunderstorm. I floored first gear and cut the wheel, threw the back end out and started drifting around. I figured i'd shift second to keep it going without bouncing off rev limiter. When i shifter second the RPMS sat at 3k and the car didn't move. When I pressed down the clutch it clicked all the way down and there was no pressure then it sprung back up and it was fine again. There was this strong smell too but it didn't smell like clutch, it smelt like burnt electronics. What did i do?! I have an extra engine and trans from a 1993 so Ill swap it anyway.
Yup, clutch (and brakes) tend to smell like roasted electronics. Could be the springs on the pressure plate are getting weak causing it to slip under load. Take it on the highway, and in 4th gear stand on the throttle and see if the RPM's go up without takeoff.
*There could also be some other related issue if the pedal doesn't want to return on it's own, like the throwout arm/pivot ball or MC.
