my clutch gets stuck is it a lemon z
Nissan 350z / Nissan 370z general community discussion forum
my08350z
Car: 350z
so when i drive my Z maybe once a day in first gear and 2nd my clutch will get stuck.. and not pop back up and its making me not able 2 drive because its dangerous.. any1 have any idea what it could be..i brot into nissan and they couldnt find anything but it does happen and not just 2 me.what can i do ?anywere in first and 2nd the clutch just doesnt come out. and i just rolll back till i brake.. it sux. i have to floor it to get going and then u smell crap. id dunno sum1 help
JETPILOT
When you are sick you go to a doctor. When your car is sick you bring it to a repair shop. I see a repair shop in your future. It never occured to you a repair shops would be a good idea?
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
someone else on here had a similar problem... i don't remember their solution and cannot find it right now.... take back to nissan and tell them to check out your clutch.... if they say there is nothing wrong ask to talk to the mechanic or a higher up person because there is something wrong.... good luck
xjmxstac
Car: 2003 nissan 350z track edition
Found it! This might help.zerothread/291952If you are not so mechanically inclined, I suggest you take JET's advice.
ZUL8ERmark
Car: 2006.5 350z
Hey i had the same problem i hated it but i got a 6 puck z1 clutch and never had a prob again and still loving it. the only way to fix my was get a better clutch
Chad@CompetitionClutch
if you end up needing a new clutch and flywheel set-up shoot me an email ill help you all i can.
hell right now i have a VQ35DE flywheel that was in a car for 1 mile, BARELY used, i can sell you that cheap.
Outkast
Car: 05 Titan 4WD CC, 00 Maxima SE 5spd, 91 TTZ
If it's an 08 like youre SN implies then there is a recall on the slave cylinder/ TOB. Get it checked to see if it has been done.
my08350z
Car: 350z
h
Outkast wrote:If it's an 08 like youre SN implies then there is a recall on the slave cylinder/ TOB. Get it checked to see if it has been done.
hhow do i go about a recall, and about the clutch . how much r we talking
sluggoZ
Car: 2004.5 Nissan 350Z Touring Roadster Super Black/Black
my08350z wrote:h hhow do i go about a recall, and about the clutch . how much r we talking
Is your Z still under warranty?
If so, demand a new clutch.
There have been Technical Service Bullentins about transmission's, clutch & etc.
If it's under warranty...no charge!
Your dealer might be giving you the 'run around'...I just don't know.If your not satisfied....take it to another Nissan dealer.
tommy314
Car: 08 Nissan 350Z
My clutch started sticking yesterday to the point where I had to lift it back up with my foot. Took it to the dealership and they said they could not find any abnormalities with it. Then I insisted that I go on a test dive with a mechanic. It did not happen during the whole test drive..lol..but I convinced them that I was not crazy and they ordered a new slave cylinder. I'm just waiting on the part to arrive and hopefully this will fix the problem.
my08350z
Car: 350z
HOPLY SH1T DUDE i went on a testdrive with the technision BUT WHEN I WS WITH HIM it happened.. and he was like no thats normal the clutch is OVERHEATING lol??? wth? a clutch over heats from normal drive... THEY HAVE TO REPLACE IT they say cuz its not under warrenty because its wear and tear.. well 6000 MILES ISNT A FKIN WEAR ANDTEAR. i mean sh1t and yea i got the5yr/100k warrenty
blastoff99
Car: SO 350Z
Warranties, even extended warranties, will not cover clutches. A clutch is considered a wear item.
And yes, you can wear one out in 6000 miles, depending on your driving habits.
For sure have them check your VIN to see if the slave cylinder recall applies to your car. If it does, they should have no objections to doing it, because Nissan pays them nicely to perform warranty work. I thought this issue only applied to 2007 models, but I could be wrong.
tommy314
Car: 08 Nissan 350Z
Just a quick update...My nissan dealership ordered and replaced the slave cylinder for free yesterday and the clutch is working perfectly again. They said it was covered in my warranty because "technically it's not the clutch, it's a component of the clutch." I was not going to argue with that!!
blastoff99
Car: SO 350Z
tommy314 wrote:Just a quick update...My nissan dealership ordered and replaced the slave cylinder for free yesterday and the clutch is working perfectly again. They said it was covered in my warranty because "technically it's not the clutch, it's a component of the clutch." I was not going to argue with that!!
Correct. The clutch assembly itself (throwout bearing, pressure plate, flywheel) is a wear item, but the master and slave cylinders are not.
OP, one other thing: your Z is not a lemon, at least not yet. Lemon laws vary from state to state, but usually the deal is that your car has to be into the dealer for the exact same problem at least three times without a fix being effected. I would encourage you to document everything carefully, including who said what and when. I would also encourage you to be as nice as possible with your service writer, as his or her help will be needed to get a lemon law claim pushed through if it comes to that. Also, they might be able to help you if you have to take this to NNA, which would be the next level, before a lemon law filing.
saschamarion
Car: 370z
I hope u got ur vehicle fix by now.. I got my 370z the end of february and it has just a little bit over 6,000 miles and my clutch got really stuck, my car had to be towed and they replaced the transmission just today, my car does not drive the same, the clutch does not feel the same. I honestly don't know what to say, now my windows don't go up. Not a very good day for me.
Return to “350z / 370z Discussion”
