paysonboy801 »
https://forums.nicoclub.com/paysonboy801-u33349.html
Fri Mar 03, 2006 8:28 pm
does it only happen when your driving? or does it do it all the time? I brought mine in to nissan because it was doing the same thing and It finaly pissed me off enough, well what it ended up being was it was popping the code for a leaky fuel injector which doesn't actualy tell you anything except your running to rich, now at some RPM's your air fuel ratio is a little messed up usualy around 3000 if your timmings off in either direction you would start popping a code that would turn off then come back on then off then on and so on and so on. so If thats the case just have your timing set
20 degrees Below I think is the correct amount...or is it 12 I never can remember exactly, I just use the cup of water method and it gets you with in a few degrees
