frankoV »
https://forums.nicoclub.com/frankov-u85137.html
Mon Jan 12, 2009 4:26 am
CORROSION WARRANTY
Surface CorrosionSurface corrosion of any body sheet metal is covered by the 36 months/60,000 kilometres Basic Warranty, except for those items listed elsewhere under the caption “Limitations” and “What is Not Covered”. Surface corrosion means corrosion affecting any readily visible surface area of any component of the vehicle body, but not including the vehicle underbody.
Perforation from CorrosionOriginal equipment vehicle body sheet metal components are warranted to be free of “Perforation from Corrosion”, defined as rust through, from the inner surface to the outer surface, resulting in a hole. The duration of this warranty is 60 months from the warranty start date*.* See page 3 “Warranty Start Date and Applicability”. Except for those itemslisted elsewhere under the caption “Limitations” and “What is Not Covered”.
DOES NOT COVER:• Body panel rust caused by lack of maintenance, abuse, or accident• Rust where paint has been damaged by stone chipping or debris from theroad.• Rust caused by environmental fallout, or, hail, tree sap, salt orsubmersion in water, sand or mud.• Exhaust system components• Corrosion of outer trim parts , such as mouldings. However, corrosion ofouter trim parts are warranted for 12 months/20,000 kilometers(whichever occurs first).Special bodies or equipment not manufactured or supplied by Nissan.
this is the Canadian warranty; I imagine the US warranty is near the same.
