krash »
https://forums.nicoclub.com/krash-u27755.html
Tue Jun 22, 2010 6:24 am
Sounds like you have some dead cylinders. Turn the car on and unplug a spark plug wire (not from the coil! from the valve cover) and see if there is any change in idling. If there is, then that cylinder is working. If not, then that cylinder is not firing. From there you can troubleshoot. Spark plugs, spark plug wires, coil, distributor, fuel injector, fuel rail, etc. I've even heard of the ECU being a problem. My sister's vert used to do the exact same thing. I changed the injectors three times AND changed the fuel rail out. Also changed the wires and the spark plugs. Problem still kept coming back. I changed the ECU and it seemed to fix it.
