awdjdmtalon »
https://forums.nicoclub.com/awdjdmtalon-u98681.html
Tue Aug 12, 2008 8:46 am
Alignments are usually only covered for 12 months or 1200 miles. You can call them and check. But if you have any wheel damage, you are out of luck.
And the shop that looked at it may be right w/ the radial pull. Try swapping the front tires and go for a short drive. ( I know they are directional, this is for testing only) If the car pulls the other direction, then that is the problem. If it still pulls the same way, you have a caster issue. And caster is not an adjustable value on the G.
Toe will not cause the car to pull, neither will camber. Caster does, due to the differace in the center line of the 2 front wheels. One wheel will be either slightly forward or rearward of the other. And that will cause a pull.
