rsmithdrift »
https://forums.nicoclub.com/rsmithdrift-u36706.html
Fri Apr 14, 2006 7:12 pm
Your bassackwards..............Most people want their car to keep running when it's idleing.
Well if you want it to idle bad and die then you can just unplug an injector or two. I suppose that'll make it die.
Why would you want it do die??
BTW.........Funny, related story.................I had my Z ghost ride into my dads porch one day because I started the car from oustide of it. I didn't push in the clutch thinking it was in neutral, turned out it was in 1st gear and it took off. The e-brake was up and it was on flat ground and it just started right up and got to about 10mph with NOBODY in the car.
I ran and caught up to it right as it took out a support beam for the porch. Demolished the beam.................did nothing to the car.
That's why that switch on the clutch pedal is there. To keep you from doing that. '84 300zx don't have them. lol.
