DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Jun 10, 2003 8:09 am
Leaky injectors are exactly that: leaky. When you shut your car off the fuel rail has over 30psi of pressure in it. If a seal is bad or if the injector is stuck open, it will dump fuel into the cylinder until the fuel pressure goes to 0. Gas pedal not needed.
With the limited info I have I wouldn't put money on any guess, but this is what I read:1) the car wouldn't start (the first 20 times)2) the car started right up after the normal rich fuel flow was cut off
A leaky injector is probably the most common problem that might have caused those symptoms, unless the car was driven a short distance before the problem happened.
