Sinna23 »
https://forums.nicoclub.com/sinna23-u134524.html
Fri May 22, 2009 3:59 pm
I Bought a shell and then put a regular stock SOHC KA in it. I put everything on it like wireharness, ECU, all hoses are correct (Vacuum and heater hoses), spark plugs are new and wires, oil is good, no leaks, altanator and starter are new, battery is good, but missing the EGR valve pipe and holes are not pluged. My questions are if that pipe isn't there would that be the cause of it not turning over? and if that's not the problem what else could the problem be? What else can i check to see why the car won't start?
Thank you for your time and i will appreciate anybodys input and opinions...
