sil8tdrftr »
https://forums.nicoclub.com/sil8tdrftr-u37070.html
Mon Jan 14, 2008 7:44 pm
if it is then check the clutch neutral bypass switch... i think thats what its called...
anyway its right under the clutch pedal. it could be that your clutch pedal has a hole thats supposed to be filled by a hard rubber plug that when you push the clutch down it presses the clutch switch down .... thus allowing the car to start...
if there is a hole and the rubber plug is missing... use a penny and some kind of tape like duct tape or electrical tape to secure the penny in the hole... then try starting the car...
also check to hear if your fuel pump is working just in case
