Postby
VinceSez »
https://forums.nicoclub.com/vincesez-u27567.htmlSun Oct 09, 2005 11:56 am
I have a 91 240sx with a weird problem that I can't seem to solve. When my car get's really warm it begins to bog/choke. When this happens the car begins to slow down and bog/choke around 25-30mph. The speedometer would usually bounch between 25-30mph when this happens. I recently had the head resurfaced as a result of a blown headgasket. I've also had a new MAFS put in, as well as a sensor located just behind and below the intake manifold. Does anyone know what the problem could be?
I also noticed that this started to happen more often after I installed my Hotshot Headers. Could my engine be choking as a result of the restrictive factory exhaust I have?
Postby
chrislis »
https://forums.nicoclub.com/chrislis-u32094.htmlSun Oct 09, 2005 12:46 pm
i've heard problems with installs on intercoolers and how if one of the couplers or pipes comes loose the car starts boggind down. the headers could probably cause the same thing if it's not fastened right.
Postby
VinceSez »
https://forums.nicoclub.com/vincesez-u27567.htmlSun Oct 09, 2005 4:05 pm
i might head down to a local muffler shop, or even Midas to have the exhaust system changed... kind of cheap but i need the car fixed before school on tues.
Postby
Kenrik »
https://forums.nicoclub.com/kenrik-u28233.htmlSun Oct 09, 2005 5:00 pm
VinceSez wrote:i might head down to a local muffler shop, or even Midas to have the exhaust system changed... kind of cheap but i need the car fixed before school on tues.
Not Midas... they will try to charge you $600 for nothing...
