MOB240https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113my car will not get out of park even when i push the brake in!!!Sat Feb 03, 2007 8:49 am
Postby
tintingkc »
https://forums.nicoclub.com/tintingkc-u53378.htmlSat Feb 03, 2007 9:59 pm
Sounds like the nuetral safty switch. Its located at the base of the shifter under the top cover. You can bypass it real easy until you replace it if thats your problem.
Postby
rogoman »
https://forums.nicoclub.com/rogoman-u37451.htmlWed Feb 07, 2007 11:34 am
There are several components of the 'shift lock system'. Check the harness connectors; reseat if needed. Here's a picture of the various components that are located in the dash area:
