LoserCard »
https://forums.nicoclub.com/losercard-u78523.html
Mon Feb 14, 2011 1:07 am
Other problems may be dying ignition switch, but that is usually associated with other electronic failures. Also starters, because when their brushes wear down there might be gaps between electrical contacts, thus lack of starting or slow starting. For battery, a simple multimeter will do the trick. Alternator, you should be able to run directly off the alternator if it is good.
