my car shakes like crazy!
nissan789
Yo this is h0m0. The motor and transmission mounts were just replaced, and teh car still shakes. It wasn't that bad after the motor mounts were replaced, but the 2nd time i drove the car it shook again. The whole car shakes like moneys. The motor is like going left and right. booo! Should i window weld the mounts?
180sxxx
Car: 1995 supra TT
put a v8 in it then u will have a reason for it to shake.
grieverr
Car: 95 240sx
Does it shake all the time, at idle, higher speeds..etc.
Razi
Car: Moo
Have you considered looking at other areas other than the mounts?wtf is this slang "it shakes like moneys"
94_240sx
Car: 94_240SX
Sounds like one of the injectors is out.
frosti108
Car: rb s13 coupe
shake ya money maker like you shakin it for some paper !
yea it sounds like your crap is missin on a cyl or 2 pull the rail and injectors out to see if they all skeet skeet and pull each spark plug out at a time to see if they all zap zap, y0h
dickie
Car: Killer Turtle
wow. i moved this to the tech section where there was literally a post about this exact same problem a week ago. you need to start SEARCHING if you expect to get anywhere.
frosti108
Car: rb s13 coupe
my car shakes like CRAZY too actually... but i sorta have solid mounts hahaha... so yea, my whole interior is coming out or else it all rattles and crap. i like it though
3r1c
Car: 93 Red S13 Hatchback
If your car shakes during idle and sound like a VW Bug and a knockoff muscle car then its one of your injectors.
nissan789
Ok it shakes at idle nutral and low rpms at first. once you begine driving its pretty smooth. I also put some lucas injector cleaner, and seafoamed 2 months ago. so ya.
nissan789
hello?
zachary29
Car: 89 two-tone coupe
check your plugs, injectors, do a compression test. it could be a couple of things. i had a problem where when i would try to accelrate at low rpm the engine almost felt like it was cutting on and off. i replaced the plugs and wires and it was solid again. also check your plugs to help diagnose your injectors and see how your fuel is burning
nissan789
ok i dont know how to change spark plugs. injectors are on the lft side of motor on top of sohc?
it doesnt shake when drivin faster tho
MY92SX
Car: 1992 Nissan 240SX
These cars eat injectors. Also check the Ohms resistance to spec on your spark plug wires. Pull your plugs after running for about 10 minutes at about 50 mph. If the plug is wet or smells like gas it could be the resistance build-up in older spark plug wires. If it's dry, more likely an injector is shot.
nissan789
so i should change the spark plugs and fuel injectors? heres a pic of my motor. i gues you can cirlce the fuel injectors. i think i know where they are not sure. also should i get them from autozone?
ok i dont have pics.
omg i just noticed that its sakier than before i replaced motor mounts.
heres a before video. its like no roking
Fla240sx
is it SOHC?
Fla240sx
here I circled mine, passenger side of car next to valve cover, which mine is off
make sure its connected good, like start it up, leave it running... wiggle wires, connector, push on connector.. see if it helps..... find an injector at the junkyard and try it on the #4 cylinder if that doesn't help... usually a bad fuel injector will cause a NASTY vibration... happened to me, was wiring loose.....
nissan789
i wont get shocked or anything right? ok which one it the 4th cylinder?
can i get an injector at autpzone?
by lookin at the vid does it sound like a exaust leak and lifter tick? i know a little off topic
Fla240sx
holy fawken exhaust leak man!
autozone should have em
your clutch fan needs replacing/removal as well
nissan789
ok clutch fan is the big white fan? how would i replaced that big ole thing. lol how can you tell it needs replacing?
also i check my injectors by pushing them in?
sry im noob to this motor stuf cuz im 15 but your a good help man
Fla240sx
yeah like gently touch the wires with a finger or two and move them around
push down on the connector going to the fuel injector.....
the clutch fan is that big white fan
you can take it off completely and replace with an electric fan....... thats the best way
it makes that hideous noise, so its working hard.... take it off and it will be a lot more quiet and you will be able to hear the actual engine better
search around here for how to wire up an electric fan
damn near anything from a junkyard will work that fits in the space.. you can get fans from a junkyard for like 15 bucks........
also you need to fix that exhaust leak.... jack it up
leave it running get under car.... if you can't hear where its comming from....... start running your hands about 1-2" away from exhaust... don't touch the actual piping as its hot.. and when you get to the exhaust leak, you should feel air blowing into your hand.......
nissan789
the leaks comin from dp. im getting that fizxed. how do i take off the fan?
you got aim?
Kung Fu Grip
Car: 93' fastback
I say just throw a dualcam Ka in it.
Chuki s13 ftw!!
Fla240sx
single cam FTW
to take off the fan is very easy!
I believe they are 10mm nuts, maybe 12mm
best to use a gearwrench if you have one:
you will notice 4 nuts on the water pump pulley that has the clutch fan attached to them.... you will take off those 4 nuts, take off fan assembly, then put back on the 4 nuts equally and space out how you tighten them as you will have to straighten out the water pump pulley..... it has tension on it from the belt so when you loosen all the nuts it will c*** to one side a bit.......just tighten down the bolts like your tightening wheel lug nuts and it will straighten back out normally.........
takes like 2 minutes
need to take out fan shroud....... thats a lil more work......... but I think some 10's around the radiator area and on the side of the shroud remove it.....
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
nissan789 wrote:Yo this is h0m0. The motor and transmission mounts were just replaced, and teh car still shakes. It wasn't that bad after the motor mounts were replaced, but the 2nd time i drove the car it shook again. The whole car shakes like moneys. The motor is like going left and right. booo! Should i window weld the mounts?
Before you start pulling fuel injectors and possibly wasting your time and money, first do the proper diagnostic steps to determine where your bad cylinder(s) is. Here's what you do:- while the motor is idling, pull one plug wire, off then back on, at a time. When the wire is off, observe the idle quality. Does it get worse or is there no change. If there's no change, you've got a bad cylinder.- At the bad cylinder, determine if there's ignition. Plug in a spare spark plug into the ignition wire end and lay the plug on it's side on top of the valve cover. Start the motor up and see if you've got spark.- If you've got spark, then the fuel injector may be bad or there's an electrical problem or there's no fuel reaching the injector.
nissan789
omg this is so comlicated to a 15 yr old. geeeee.
3r1c
The instructions they gave out are all pretty easy stuff. You should not have bought a 240sx if you do not know or have the money to fix it they aren't Honda Civics you know.
Kung Fu Grip
Car: 93' fastback
nissan789 wrote:omg this is so comlicated to a 15 yr old. geeeee.
Its because the s13 doesn't like you! Now go put a SR in it along with some Nismo mounts and it should stop making a ruckus. hahaha
You have to over come the power and show the s13 who's boss or it will not show you it's true form.
nissan789
i have time and money son. im learnin
