HeavyDuty »
https://forums.nicoclub.com/heavyduty-u10182.html
Fri Mar 12, 2004 5:46 pm
dkill is right, turn it to the 'on' position, *not* 'start'. Listen for the pump priming for a couple of seconds, then turn to 'off' & repeat 4-5 times. This should prime the pump again. If you do not hear a faint 'hmmmmmmmm' from the trunk area when in the 'on' position, then you have more problems than a lack of fuel, like a bad pump or fuel pump control unit, FPCU.
