My Car Pics! 56k...buy an SR
HolyShiznit
Car: Working on my car
Ok I post enough but I don't have any proof that I do exist, I will get more pics and you guys can request stuff if you want. Please feel free to comment or ask questions.....
On with the show!
Cliff notes, my car is the white car. The darker KA-T is my buddy Rob, expect him to be either beating or competing with Rick and Ivan for high HP numbers within the next 3 months. EDIT: Forgot to say my fastest time so far has been a 12.7, however on my new set-up I went 13.0 @ 120 with a 2.48 60'. I forgot to air down the drag radials so I burnt out so much that I never even reached full boost.
Craving4Boost
Car: 91 240sx fastback
why you making me read your dyno sideways
NateDogg
Well done.
What's the setup?
DammitBobby
Car: S13 91 KA24DET
Looks clean! Got any more info on the engine or more pics?
fiznat
Car: Grown up :(
Ive said it once and I'll say it again--- BE CAREFUL with those stock rods! haha.. Car looks awesome though man, I'm jealous. Whats with the hole in front of your d/s tire?
HolyShiznit
Specs are 93' 240sx. 108,000 miles on the chasis, 1,250 miles on new motor.
Crower Springs/RetainersCrower V3 Cams (waiting....cause Crower sucks)Full Port and Polish (gasket matched) 91 HeadFull Port and Polish (gasket matched/both parts) Intake ManifoldSuperTech 9:1 PistonsClevite BearingsARP Studs (head/main/rods)STOCK RODS (bite me!)Spearco 24x6x3 FMICBoostDesigns Tubular Manifold (redone/rewelded, POS)Tial 38mm Wastegate (external dump out front fender)Super T3 60 Turbo (thought it was a T3/T4 for 3 years....)JGY Fuel Rail75lb InjectorsJWT ECU (Ewww)A'PEXi SAFC IIA'PEXi Turbo Timer (no face plate thanks to thieves)A'PEXi AVCR PLX-M300 WidebandGreddy 52mm Boost GaugeGreddy 52mm EGT GaugeMSD SCiMSD Blaster Coil 2Spec Stage 4 Clutch
Best of all, BRAND NEW 350z Aspen/Frost White paint job!
More pics are on there way. Anything in particular you guys want?
Modified by HolyShiznit at 11:33 AM 9/1/2005
koukiKA240
Car: 1991 240sx KA-T
looks good, whats that hole in your fender near ur blinker?~Sam
veilside180sx
Hole in his fender looks like an external wastegate dump pipe.=)
koukiKA240
strange, i dont think i would want exhaust all over the side of my new paint job. ~Sam
Structure240sx
it is a wastegate dump tube, in close up pics you can see its done nicely with a metal plate around it to keep the paint from getting ruined
good work job looks great
DammitBobby
Car: S13 91 KA24DET
Ah BD manifold. I love to see the pics of changes you made. Did you have problems with the manifold?
slipnfall
Car: '06 D40
I'm not really diggin' the wheel/tire combo on that coupe... <shrug> to each his own I suppose.
lol is that a coffee can on your fluid res?? Nice!
Those gram light wheels?
nissanfanatic
Car: 1992 Nissan 240sx SE
Nice nice...
Quote »Anything in particular you guys want?[/quote]A big smoky burnout!!! :p
HolyShiznit
The wheel/tire combo on the coupe is 5 lug Typhoons with 235/255 staggered. They are very nice. *shrug*
As Anthony said, I have a very nice stainless steel plate on it to protect the paint. (surprised you guys can't see it)
Yes the BD manifold needed work. The inside needed hella porting, the runners at the flange all needed to be ported out to match because the metal wasn't lined up at all. The wastegate extension fell off...literally. I had to limp it home and weld it back on and add all my own new pieces to keep it together.
More pics of the engine build and wastegate dump will be coming.
HolyShiznit
More Pics!!! This is mainly of the build I did over the summer. Oh and if anyone can get the picture of the turbo/manifold/block into an avatar size and send it to me I would love you FOREVER. The shiner downpipe is my new one vs my old one. Old one was more or less a test bed for a bunch of my previous set-ups.
HolyShiznit
Last one, this is for Anthony, AKA Structure....
hannibal
Car: Red Line to Glenmont
Impressive build list! Your car looks great. I'm really interested in your turbo. Its a Super 60 wheel in a T3 housing? What was your previous setup that you mentioned?
BTW, I like the Typhoon wheels on the coupe. Cant wait to see if he can up the bar.
HolyShiznit
IWannaS15 wrote:Impressive build list! Your car looks great. I'm really interested in your turbo. Its a Super 60 wheel in a T3 housing? What was your previous setup that you mentioned?
Previous set-up was SAFC II/370cc 8.7 psi, then JWT ECU/52lb/SAFCII 14.7 psi, and now this. Ya I need bigger turbo. I am gonna play with the timing this week and straight up go crazy.
I called Crower today and Brian said, "I have no ETA". Hooray! Crower sucks and I still don't have the power band I want.
Structure240sx
wonder if anyone will photochop you
TheOne
Car: 93 240sx FB
structure should start the ps'ing....since he got 0wned at his thread,lol.
anywayz, man that engine looks so nice painted black block with rest normal(i had mine that way, it was a stock motor though, and it blew cause i forgot to put 1 of the o-rings that go around the oil pump)....and thats not a bad idea for the dump pipe:).
WDRacing
HE's not ripped enough Tony...lol.
Nice job on the car man. Looks awsome. I love the dump pipe routing. I was going to have my whole down pipe dump just behind the front tire. No muffler required.
Tictakman
did u brace the dump pipe at all? i was gonna do the same thing but i have to wait for my phatkat mani to come in.
Zak
HolyShiznit
Tictakman wrote:did u brace the dump pipe at all? i was gonna do the same thing but i have to wait for my phatkat mani to come in.
Zak
Yes it's braced in two places, one right off the fender to bumper connection (just welded a piece on and drilled a hole), and the other...actually I forgot what I did for the other one, I will check tomorrow. You guys want pics of the routing?
TheOne
Car: 93 240sx FB
i wouldn't mind a couple of pics inside there, to see how it goes.
Fenvy
Car: 2005 350Z Base 6MT
what is that hole on the side?
HolyShiznit
Loveless wrote:what is that hole on the side?
Read.... Everyone is discussing it, it's the dump tube for my wastegate.
I will get pics of the routing tomorrow when it's light out.
Craving4Boost
hey anthony i doubt your easy 3 steps now.....doesnt look like it works
lol jk
SOHCSE
Car: 1990 240sx SE
HolyShiznit wrote: Oh and if anyone can get the picture of the turbo/manifold/block into an avatar size and send it to me I would love you FOREVER.
Hey, I think I gots something for ya!
-Matt
HolyShiznit
w00t Kick *** buddy you rule! More pics coming in a sec guys.
1WheelWonder
Car: 1991 Nissan 240sx
Awesome setup man, really clean.
