ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Fri Jun 30, 2006 6:09 pm
hmm, what ben is hunting for is if the mech fan /shroud are still in place; check for the fan clutch... oozing fluid from the center of it= new fan clutch time!
mech fan is not producing enough air flow mebbe d/t a failing fan clutch or missing shroud or mebbe obstruction between the condensor & radiator (leaves can get stuck in between them)...
also, the OEM electrical a/c condensor fan shoulda kicked in once a certain temp is reached by the lower hose sensor... ~208 degrees F
of course, this is assuming that your cooling system is healthy to begin with...
venture over the free FSM download for more info!
