Q45tech wrote:The software contains a coolant temperature vs ignition retard section to protect against overheats and reduce knock...............on some this starts at 195F and 200F on others. Turning the AC on signals ecu that it is summer. Gasoline composition shifts in October to winter blend which often has a high btu content and create more torque vs Summer blends.
Always make sure the cooling system is kept as new to avoid these excessive temperatures.
Great post! Do they have a winter blend for Florida, too? I never thougth about that.
SPEAKING about keeping the cooling system clean, I tried to flush out mine today, but I COULD NOT FIND THE STOPCOCK ON MY RADIATOR!
I swear that I looked for it but no luck. The stock radiator has it on the driver's side, but I have a replacement radiator which means that it could be anywhere.
But, unless it is hidden below the under engine cover, I do not knw where it could be.
HELP?
