MY CAR KEEPS DYING!!!!
300TT
Car: Nissan 240 sx
every time i come to a stop my car just dies.... i dont know if its the fuel injectors/fuel filter but some one said maybe its the gear box? i dont know i just need a good opion...
x240xdrifter
Car: 1991 Nissan 240sx
a car needs three things to run
compression
spark
fuel
check to make sure you got em
tbone24000
Car: 1991 240sx sr20det
sounds like you could have a vacuum leak.
D21_Destroyer
Car: 1992 D21 Nissan Pickup 2.4L King Cab RWD
I had this problem at one point. The first two things we checked were the MAF, and the gaskets. I think i ended up having a blown gasket ( i don't remember which one) and it would cause the engine to stall whenever i took my foot off the gas. Check that out, if it's just a gasket it should be a relatively cheap fix.
sleepyS14
Car: 1997 Nissan 240SX 2JZ30DETT
2006 SAAB 9-2X AERO
300TT wrote:every time i come to a stop my car just dies.... i dont know if its the fuel injectors/fuel filter but some one said maybe its the gear box? i dont know i just need a good opion...
+1 for MAFS... try unplugging it.. cleaning it up and such.
and second.. did you put an aftermarket intake on? .. if so.. it's possible one of the hoses popped off causing the car to die. that happend to me.. just had to reclamp it and all was well.
definitely check the MAFS tho
jinjinweiwei
Car: 95 240SX
replace your MAF!!!!!!! that fixed mine =D
xekushnr
Car: '90 Nissan 240SX Hatch
check ALL your vacuum lines. im fairly sure this is the problem.
VanguishRacing
Car: nissan 240
1. check your maf2. check your spark plugs, it might foul out.
MAGILLA
Car: 95' 240 se
fuel filter would also cause that. I would change that first since it is so cheap and easy to do.
VanguishRacing
Car: nissan 240
beside of purchasing a oe fuel pump...rather get a walbro 255. a better response.
rps-13
Car: 1993 ka24de 240SX fastback
hi guys Im having the exact same problem only thmy fuel filter is new my fuel pump is working and I have cleaned the throttle and the maf sensor but only one thing is buggin me why if I disconnect the maf sensor it idles good and if I connect it it dies i disposed of all the emission hoses exept for the one that goes into the fuel pressure reg all the other ones ive plug the tight. SO any suggestions???
