My car is screwing with me
Biggins240sx
Car: 1992 Nissan 240sx Stock KA24DE 180,XXX
Alright so to start off i had a problem with one of my injectors. It went out on me and started pouring gas into my cylinder. So I replaced it today. Started my car up, had lots of smoke come out the exhaust from all the gas. But the problem is when i open the throttle my car bogs down and dies. :tisk: But If I open it slowly and keep it opened only slightly it will accelerate .So i checked for codes. I got codes 12, 21 and 34. Maf sensor, ignition input signal, and knock sensor. So i did all the tests on each component according to the fsm, and all components check out fine. But i still get the codes. I checked the wires for voltage in the correct spots. Checked for continuity where it shoud be. I just can't figure it out. :wtf2: I'm thinking maybe i need to fill my car up with gas, cause it is low. And thinking fuel pressure, but i can't get the car to the gas station without moving.
Any input will help! :confused:
RideNslidE
Car: 1993 240 hatch the track and a 1993 240 vert DD
Have you checked for vacuum leaks? also at idle does it run smoothly?
Biggins240sx
Alright i figured it out. Call me stupid, cause i forgot I took my gas cap off and put it on the door. And I decided to wash my car in between fixing it, so I got water in my gas tank. Bought a bottle of heet and a gallon of gas. Put that in there, started it up. Let in run for a min. Now it works fine. Water is bad!
uber240times2
Car: 1989 240sx hatch
2003 350z
Betcha got a nice clean engine in there now lol.
Biggins240sx
I always try to keep my car clean. engine bay and all. I don't like loose oil or anything. Makes it a bigger mess when you try to work on it.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Check for leaks, check fuel pressure, clean the IAC, and throttle body, set the TPS, try a product called MAF clean. I also wonder if the 02 sensor is healthy.
Biggins240sx
It was just water in the gas. I took care of it
