wmdavis007 »
https://forums.nicoclub.com/wmdavis007-u35898.html
Fri Mar 27, 2009 11:49 pm
Hopefully it's a plug and play alarm system, where you can just unplug everything and plug your OEM harnesses back together...if not your going to spend a few nights tracking down, cutting out old wiring, re-splicing and soldering a ton. If it's spliced into your harness I would highly suggest soldering, heat shrinking and taping all your connections (not just using crimp style butt splicers) or you will have problems down the road.
Few years ago I helped a friend take out an old alarm system...sheesh...we should have just bought a brand new complete harness for his truck. But hopefully yours isn't that bad.
But to try and answer your question, where to start...I would remove the lower dash panel under your steering column and start there...looking for the alarm control box...could be closer to the ECU behind the glove box and behind the passenger kick panel as well. Also check in the engine bay...no telling where some folks mount them. All I can say is good luck...if you have questions about anything take some good pics and post them up...maybe we can help you more that way.
