my car is learching!
ColbyS15
Car: 1991 Nissan 240SX 2DR Coupe
when i drive i have to put my car into neutral at stops because if i dont it begins to rock and it is only at very low RPMs (500 or so), i hit a tree when it started...it smashed the left front side in a bit no major damage, missed the radiator by a few inches, i did disconnect and air hose that goes to my air box though and it isnt inline with the other part of the hose so i cant reconnect it. would that be the reason for the car learching or if not does ne1 kno y it mite b?
s13sr20chris
disconnected an air hose by air box? does the maf have air going through it with this setup? what kind of car? does it feel like a misfire or just running rough?
ColbyS15
first of all...sry im not very car literate as of yet...maf??? explain please and its like its running rough. but it has fits...if i drive for mayb 15-20 minutes it doesnt usually rock anymore...but at first it feels like it wants to jump forward but it cant. and i put it into neutral a lot now....is that gunna **** with my transmission or will it b fine?
s13sr20chris
going to neutral is ok. the maf is the sensor on the airbox. if you arnt familiar with it then it would be best to leave it alone. i can just reccomend that you do some basic inspections. the basic inspections are layed out in the sticky above on drivability issues.
ColbyS15
alrite thnx for all ur help
Altiman94
Car: 1989 Nissan 240SX
my 240 used to do this at times, I found it to be a vacuum leak.
