My car is dead
chris1212
Car: 1996 240sx
I didnt unhook the batt when installing a starter. so the hot wire arked and i blew something. i've pulled all fuses inside and out and none are blown..can it be a relay or is there a main fuse? i dont know how to check the square type plug ins..the car has no electrical power at all...1996 240sx
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
you probably popped a big fuse in the box under the hood. you can test them by using a multimeter and checking for continuity. if you dont know how to use a multimeter to check for continuity just google it, its easy.
chris1212
Car: 1996 240sx
i fixed my loose ground and im rolling again
