my car is acting funny need some advice
wannabemech
Car: nissan maxima
my car stutters when i step on the the gas pedal almost as if its not getting enough gas. it also has uneven power expenditure sometimes it takes off sometimes it just barely moves. also it makes a loud clicking sound sometimes when I step on the gas pedal. I have changed the air filter, the oil and oil filter, the fuel filter, I have run system cleaner through it fuel injector cleaner as well I do not know what to do. it is a nissan maxima 1993 not sure which engine it has though.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Is it an SE or a GXE?
If it's an SE, check your spark plugs and coils.If it's a GXE, check your plugs, wires, and distributor.
wannabemech
Car: nissan maxima
not sure its probably the cheaper one though is there a way to tell
wannabemech
Car: nissan maxima
and thank you for the help
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Look on the top of the firewall. There will be a small squarish metal plaque with the VIN and some other info on the vehicle. It'll have your engine code shown on it. If it says "VG30e" you have a GXE. If it says "VE30DE" you have an SE.
The VG30e in the GXE looks like this:
The VE30DE in the SE looks like this:
There wasn't really a "cheaper" Max with the 3rd gen. Just slightly more lux or sportier. No base model, though.
The VG30e has a mechanical distributor that may be your problem.The VE30DE has individual ignition coils that could also cause your problem.
wannabemech
Car: nissan maxima
thank you I will look into it do you have any suggested sites I should look at before attempting these procedures i am pretty new to cars but I have a friend who knows a little and is helping me
PapaTom
Car: 1990 Nissan Maxima 1993 Nissan Pathfinder 2007 Nissan Maxima
I had a similar problem. Turns out it was just a spark plug wire that came off the distributor cap. Check the simple stuff first.
