my car is accelerating funny
Henryt
Car: 1990 Nissan 240sx
i need some people's help my car is acting up. like when i acclerate from 1000 to 3000 rpm it jerk an sounds like a mucsle car. i notice there was a hole in the hose under the bpt vavle and i thought that was the problem i replaced it but it's still doing that
180fan
Car: 89 fastback
the hole in the bpt hose would give your car high NOx at the next emissions testing. If it's bucking and sounds a bit rough...
muscle car noise - check for a hole in the exhaust yet?
bucking - I'd check out a few things for this one. timing, coolant temp sensor, tps settings, and also the injectors. If it's an older car like an S13, it'd probably be the injector plugs being green from corrosion or they're just worn out. Roughness at idle I take it?
Henryt
i was thinking that it might be a vacuum leak i check the exaust an it's fine i know my injector is fine also because i know whatr it does when it's bad it was 2 degrees off tdc but now it's right but it still does that jerking bull **** somtimes
