My car idles MUCH higher as it gets cold outside, this can't be normal?
240z4u
Car: '95 Nissan 240SX
Quick question, I always forget about this until fall rolls around. I don't exactly remember where my idle is when its warm outside, but it goes up about 400rpm and hangs there when it starts getting cold out (IE 40 degrees or so ambient).
When I first start it, the idle is normal. If I sit and wait (I was getting out a CD for example), the idle ramps up very quickly and stays there. It sounds like its a bit lean too, a tad on the rough side. I can check that with the power FC though.
Anyone else experience this? I am running power FC, but the same shiz happened on stock ECU if memory serves.
Thanks guys - Evan
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Check out what your idle settings are set at on the PFC. There are settings that richen the fuel mixture for a given engine temperature. If yours is cold enough, that might be what is happening.
240z4u
Good call, I had forgotten about that. Ill check it at lunch.
Evan
BoostFab
Car: S13cp, S13fb, S14z
240z4u wrote:Good call, I had forgotten about that. Ill check it at lunch.
Evan
make sure you adjust it when the engine is warm at operating temperature;
240z4u
Hmm apparently it only happens in the morning. Ill hook up my laptop tomorrow AM.
Evan
