My car idles like hammered dung.
1WheelWonder
Car: 1991 Nissan 240sx
If you don't know my car has been turbo-ed for over 8 months now, and for the most part has run like a champ, until today. It's not so much a running problem because it does ok while driving and boosting. My problem started today after some spirited driving. At idle I usually pull about 21-22vac, but now it fluctuates from 7-3ish. My wideband usually show 14.7 at idle, but now reads lean. I can hear a nasty hiss coming from the back of the intake manifold, i'm scared to look back there because it might be a rattlesnake praying on me. I did a compression test and it came out perfect, my plugs looked well too. Oil isn't funked up looking or anything and my radiator fluid looks good. Could someone please help me.
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
what is your setup?
it sounds like you blew a intercooler pipe off or a vacuum line. if it drives fine and reads perfect AFR then i would try to use a SAFC ( if you have ) and richen the thing at idle to see if the idle smooths out.
it sounds like a simple problem but the fact that it drives fine and that its lean at idle instead of being rich all the time makes it weird. but yeah just try looking for a leak.
1WheelWonder
Thanks I will check that.
1WheelWonder
I found my problem. It was a pcv line that had blown off.
S14tat
Car: 2007 FX35
1994 Acura NSX
hahah that must've been pretty easy to find. when you say pcv line, do you mean the PCV line underneth the intake manifold or is it the breather on the valve cover?
1WheelWonder
The pain in the *** one under the intake manifold.
S14tat
Car: 2007 FX35
1994 Acura NSX
wow how did you blow that one off? well atleast you got your car running, and i know what to look for if that happens to me.
