CanuckQx4 »
https://forums.nicoclub.com/canuckqx4-u160090.html
Mon Dec 20, 2010 12:31 pm
There is definetely a tube on the firewall with a little condom on it I just went and checked after seeijng your post, that is cnnected to the cooling system?? I thought it was for the a/c system or such.
This morning I tried a few things though, I pulled my front bumped, grill and headlight to the get the overflow bottle out. I then noticed the overflow rubber hose connecting it to the rad was pinched between the overflow and the body, I cant tell if it was almost completely pinched off but the hose was prety beat I replaced it.
So I reinstalled the resevoir, topped up the rad with about a liter of coolant and put the resevoir upto the min line.. Started the car with the cap on, idle for 30 seconds then I went to pop the cap off, sure enough, coolant was a coming
I had to get here to work so I simply revved it a few times (didnt see any foamy air bubbles or anything just good coolant going on the ground) so I capped the rad and came to work
