my car dies !
natguerrero
Car: 240sx sr20det
im new to this and iv only posted a couple of things but this is a little more technical so i do know where to start looking for this problem.....
i just brought a 240sx with a sr20det red topand i haven't drove it much do to water pump that needs to be replaced.but when i start it i have to keep the rpm's over 1000then when i let off the pedal the car diesbut if the rpms hit 500 i can give it more gas and it will idle right again but when i let off the car will die ! so where can i look and what can i do ????
CotBU
Car: 180sx
check ecu for codes.check tps voltage, key on engine off. adjust via fsmraise idle via iacv if adjusting tps doesn't fix it.then check timing, set 15deg
Divine0425
Might be you fuel pump
