my car dies some times when i am driving.
kneegrowz32tt
Car: z32, 300zx tt
every single time i get into neutral the rpm gauge goes down to 100 rpm and then comes back to a normal idle. But some times when i am down shifting or going into neutral my car will almost die and all the lights come on, but some times it will just die on me.
can some one help me figure out what is going on? and is it going to be expensive?
thanks very much
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
IACV, it's a common issue, most likley cleanign will solve the problem
pahaf
Car: 91 Z32 TT
do u have blow off valves? they casue the car to stall as well.
Vanessalalinda
Car: 1990 Nissan 300ZX
duuuuuuuuuude the same thing is happening to me!! its so frustrating! it usually happens when i go from 5th to neutral and slow down fairly quickly.
What's the IACV?
evildky
06 Nissan 350Z GT
Idle Air Control Valve, search it, it's a very common problem and seems to effect dang near every one of these cars as they age, usually cleaning and lubing them does the trick
Vanessalalinda
I'll look into it and report back.
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
will sea foaming clean the iacv?
evildky
06 Nissan 350Z GT
DanDrath wrote:will sea foaming clean the iacv?
nope, you have to actually take it apart and clean it, it's an easy fix just nto that easy
Vanessalalinda
cleaned out my IACV and i didnt help =/. However, my air flow regulator is stuck open....getting a new one. hope it helps!
Vanessalalinda
ahhhhhhhhhhhhh its so much worse now!! its dying almost every time i put it in neutral. its soo frustrating! i can hardly let go of the gas pedal. this is after getting a new air flow regulator. so i might need a new IACV????
evildky
06 Nissan 350Z GT
did you adjust the iacv? get the plugs back on it right?
Vanessalalinda
Alex in Trenton is doing the work for me. He's been under that hood a good amount of hours and nothing. he wants to reclean the connectors before getting a new iacv
Vanessalalinda
im so freaking annoyed, i just replaced the air flow regulator, got new spark plugs, new idle controller and i'm still stalling when going to neutral form a high gear/speed! wtf?!!??!?!?
evildky
06 Nissan 350Z GT
maybe you should find a better tech
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
evildky wrote:maybe you should find a better tech
word . thats a ruthless. but prolly true
evildky
06 Nissan 350Z GT
not trying to be a prick it's just that if she is posting here and he is replacing parts with no sucess then neither fo them truely knows whats going on, if he knew what he was doing she wouldn't be posting here and since she's the one posting and he's doing the work there are too many ways for things to get crossed up and confused
Vanessalalinda
well that's tru. if i knew what to do i'd try it myself! ...anyways he's recommended someone else closer to me so let's see what he says.
