huguetpj »
https://forums.nicoclub.com/huguetpj-u637.html
Fri Aug 12, 2005 3:10 pm
Remove the fuel pump fuse (might be blown?) and crank it for like 10secs in order to remove all press from the system. Disconnect the fuel line going into the fuel rail and point it at some kind of container. Then put the car in ON, do not crank it. Fuel should spur out like hell into the container.
But since you have a Wabro 255HP and I know how noisy they are, before you start disconnecting stuff, do you here it turn on for 5secs after you turn the key to ON?
Also the car might have drown in fuel... you have bigger injectors? Try removing the plugs and see if they reak fuel or not.
