my car creeks
91KA
Car: 91 240 sx
yeah, so my car creeks everytime i steer all the way, left or right. as if metal will fling off if i go another inch. would this be the tie rods? if it is, i just read that tein tie rods were good. anyone have any other input with good tie rods i can purchase?
titanium240
Car: 1986 Ford Escort
Sounds like the Power steering pump to me, open the hood and have a friend turn the wheel, then try to find it by sound - I bet that's it.
if it's not, i'm bumping this post.
slc240sxse
Car: 96' 240sx SE
If the car is older, it might be your bushings. Is ti creeking loud, or is it squeek / squeeling? It could be your power steering unit, or it could just need some conditioner, or perhaps it's low on fluid.
dborelli
One more thing to look at...the bearing on the top of your front struts that allows them to turn can make a creaking/squeaking sound when you turn. Mine does it now but I don't have the cash to fix it at the moment.
Danato
Atomic-S14
Car: 2009 Altima 2.5S
dborelli wrote:One more thing to look at...the bearing on the top of your front struts that allows them to turn can make a creaking/squeaking sound when you turn. Mine does it now but I don't have the cash to fix it at the moment.
Danato
my car recently started to making some noise from the front pass. side... what needs to be replaced? and how much?
xckid
Car: 2004 Chevy Blazer ZR2
Yeah my car has been doing that for a while. Dont know what it is.
SlowBack
Car: 240sx
Alright guys here are the possibilities:
Tie rods (inner/outer)Strut mountsBall Joint on Control arm (<-I'm guessing that this is what the problem is)
You can get a new control arm with the ball joint installed (installing would require a press) from http://www.pdm-racing.com for about $60 shipped.
Hope that helps,Matt
Elemental
Car: Acura Integra
duuuuuuuude.
its an s13. they make noises. just deal with it.
Atomic-S14
mine is s14 and it started making that noise after the little accident i had with curbs... i guess the body shop didn't fix it right or didn't replace all the bad parts...
Elemental
Car: Acura Integra
oooo... eeeesh good luck with that.
mine just started makining popping noises during like 3rd gear entry drifts so... whatever man! gl with yours.
