silviamaniac »
https://forums.nicoclub.com/silviamaniac-u9235.html
Sat Mar 13, 2004 2:34 pm
I relocated the battery to the trunk for turbo install. I finally finish off and then i hook up my battery to see whatsup.
1st attempt, i hook up the battery, there are some funny sound came out at the front. thus i remove the -ve terminal immedietly.
2nd attempt, i try to clear up some wiring, and try again, this time, i hook it up, let the sound continues for a while, and the my battery fuse i installed at the back blew.
3rd attempt, i replaced my fuse, disconnect ignition, coil, maf, and reconnect battery, the car still try to crank itself.
WHY?????!!!
Pls help!
