That is false you dont always win or lose it at the light. Only time that happens if your both equal in power and no body messes up. If I line up with a 93 honda civic DX and it 100% stock and he cuts a better light than me he isn't going to win lol. Not unless the earth opens up and swallows my car and time and space itself stops after it happens.slowrb20 wrote:wrong.. you win or lose at the light.
your time starts as soon as the light comes down.
you can run a faster time than someone and still lose if they got the whole shot..
I need to get me a measuring device that takes me to the 100th Trillion place.s13point5 wrote:seriously tho, reaction time has no impact on your ET. you can sit at the light for 3 mins after the light hits green and then launch. if you go down the track at 12.89988979768978 then your time will be 12.89988979768978 regardless of your reaction time.
WhatsADSM wrote:reaction time makes no difference in ET. The time starts after the small (few inch) roll out. I.e. the time starts once your front tires move breaking the beam.
you really dont get it do you? i said 3 mins as a joke/proving a point. your time starts as soon as you roll pass the starting line. it DOES NOT start when the light turns green. if you run 12.8 if you waited a second to move, then you would still run 12.8 if you cut a .500 light. listen to us when we tell you the reaction time means NOTHING when it comes to your ET. whenever im at the track, if im lined up with my buddy then i will try to cut a good light because im racing heads up with him. if im just at the track to get times then i will sit at the light even after it turns green and make sure i concentrate on a perfect launch. hell when i had the 2step on my old civic, i didnt hit 2step till after the other car left so i could concentrate on my line and my driving.slowrb20 wrote:i was under the impression that the time starts when the light turns green.
you guys are reading to much into it. for one you wouldnt sit at the light for 3 minutes.
two. when the light turns green you launch.
if it takes you 1 second to move and you run 12.8what would you of ran if it took you .500 to move?
