Thought I had reached a point to where I was happy a couple months ago with Nistune, a GT2860RS, and DSM 450cc injectors, but then the inevitable happened... broke ring lands on 2 pistons. So instead of being like the majority of CA owners and ditching the power plant, I decided to upgrade and take my misfortune as an excuse to go fully built.
Which brings me where I am currently.
Im using the same necessities as I had before, CXRacing radiator, e-fans, FMIC, Nismo mounts, and my Nistune, just adding some goodies.
I went with 84mm Wiseco pistons, which Im just deleting the oil squirters (I know there is mixed reviews about that on here.)
K1 Rods
ARP head studs
ARP main bolts and rod bolts
The crank has been weighted and polished.
Clevite bearings
FIC 1650cc injectors (to run ethanol)
Custom intake manifold (FabW3rks)
Custom top mount turbo manifold (FabW3rks)
And the turbo I chose to go with is a dual ball bearing Precision 6262 with a .68a/r exhaust.
Tomei 270 cams with a 8.8mm lift (in & ex)
Supertech springs and retainers
Tomei cam gears
The head is being ported by Brandon Bonnewell (owner of FabW3rks)
My power goal is lofty, but again, its just a goal. I would like to settle right in the arena of 500whp. Though I will be happy with anything above 450whp.
Everything has been purchased with the exception of the cams/springs & retainers/ gears. I will also need to upgrade my ACT street/strip clutch which I purchased for my last setup not even 200 miles ago...
Eventually I will purchase the Mazworx Z32 trans adapter kit and a Z32 trans, but I simply can not afford that at the moment.
The engine is being machined and the short block assembled at CNC Engine Dynamics in Winchester, VA.
Hoping to have the complete build done right around tax time, so February/March, as funds allow.
**If anyone wants the stock cams from the CA or the ACT Street/Strip clutch, PM me**
Here are a few pictures from my last setup to where I am now:
My old setup
My 240
84mm Wiseco pistons
90mm billet throttle body for the new intake mani
K1 rods
FIC 1650cc injectors (not the fuel rail)
dbb Precision 6262
Just dropped the block off at CNC Engine Dynamics to be machined/assembled
Feel free to leave any feedback. Im not an avid poster on the forums, and usually stick to the S-Chassis Owners group on Facebook, but Im open to suggestions and feedback.
Tyler
