CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Wed Mar 08, 2006 9:11 am
well jsut got some cash to play with and deceided to spruce up the ride a little, i have most of the parts, and am awaiting others and only need ot order the turbo and clutch kit etc.. i will start the build up soon...
Engine:CA18DET block bored to 84mmCP 9:1 forged Pistons & RingsCrower Froged Steel Connecting RodsPower Enterprise 1.2mm HGPower Enterprise timing BeltNew Oil & Water PumpsTOMEI 260" ProCams & Cam GearsTOMEI high Rev Valve SrpingsCustom oil coolerARP Main & Head fasteners
Turbo & Intercooler:Garrett GT2871R - 15 52 trim (HKS GT-RS clone)Compressor: 51.2mm inducer/71mm exducer, 52 trim .60 A/RTurbine: 53.8mm w/76 trim .64 A/R TurbineHKS actuatorSSAC bottom mount manifoldGReddy Profec S boost controllerEbay 24"x12"x3" intercooler w/ 2.5" in/outletsGReddy type RS blow offHKS outlet/elbow O2 pipe (customised for CA)
Fuel & Ignition:Walbro 255lph high presure Fuel PumpAeromotive Adjustable Fuel Presure regulatorRC Engineering 550cc Injectors x4AEM Twin-Fire Capacitive Digital Ignition ModuleSplitfire RB coilsHaltech E6k & 3 bar MAP sensorAuquamist Water/Methanol Injection Kit80mm TB & Custom Intake plenum
Clutch & Drivetrain:Clutchmasters Custom Clutch KitLightweight flywheel (not sure on which yet)balanced DriveshaftR180 4.363:1 ring gear & Cusco LSD
i am moving the intercooler into the engine bay to shorten the hot and cold pipes considerably, also with going with a smaller turbo, i am going down to 2" hot pipe and 2.5-3" cold pipe.. looking for more of a responsive setup aiming for about 300-320whp @ 18psi with full boost by 3800rpm or so
should be easy, and to run 20-22psi (if the HKS actuator allows) with race fuel and water/alchohol/racefuel injection on the drag strip hope fully will yeild a very fun/fast/enjoyable ride..
looks like i am getting another ride so i can keep the CA Silvia
