my ca18det from australia
magnus in aus
Car: 89 nissan silvia
hey all my names magnus and im from australia. Heres my ca powered silvia.
Atm im installing the microtech, hks cams and the trust tdo5. Then its tune time. All the pics below of the turbo is a T28bb, had that on for a while.
89 ca18detmanual
ecu: microtech lt8
***engine***CP forged pistons and ringsacl race series bearingsservice head,bore and hone block,deck the block,resize rods,regrind crank and strighten,modify oiling,balance enginecometic head gasketacl VRS kit.GTR head studsremoved butterflieshigh capicity sumpoil cooler and relocatoroil catch can
**Fuel system**bosch 044 external pumpwalbro intake pump, lifts to surgesurge tanknew hose and speedflow fitingsnew filters
**intake/cooling***HKS cams 264 in&ex with 8.5mm liftTrust tdo5 16gTrust 35mm external waste gateTrust ss manifoldss intake pipe3 inch turbo backhybrid core with custom pipingr32 rad with 12 inch thermo fan
**running gear**kaaz 2 way diff4 puk button clutchfully adj HSD coiloversfront and rear strut bracesadj castor armsadj toe armsadj camber arms17x8 drift teks, front only
**interior**semi stripped interiorbride brixomp 3 point harnessnardi wheelhand break buttonspeco gauges, oil presure, oil temp, water tempbattry in the cabin.
heres some pics of it. my wheels on the way from japan, weds item: 17x8+10 and 17x9 +12
CadetLD
Car: 1991 Nissan 240sx Coupe
Awsome first post! Welcome to Nico. What kind of power were you making with the t28 and what are your expectations from the TD05?
Bwana
Car: Denali
Very, very nice! Those weds are sick!
Welcome!
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
not a big fan of the kit, but dear god that motor is sexy as HELL.
bentvalves
Car: 89 Silvia K's
What did you put in the enlarged pan to keep oil centered?
Swinging baffles of some sort, on hinges?
Do you ever get freaked out about going into your garage and possibly getting bit by a rattlesnake when you reach where you shouldnt?
ca18detgabby
03 Infiniti G35
Any idea where I might find a Trust exhaust manifold for sale???????
magnus in aus
I never got my car dyno'd with the T28. With the new setup im hoping to make close to 300hp on 19psi.
here in aus where i live, i have the choice of three tracks to slide. 2 tight and technical go kart tracks and 1 v8 supercar track, which is 3rd and 4th gear. So i think the td05 will serve me well for the drift tracks.
for the sump we just used hinges on each side. Sump holds 5L without oil cooler. Where do i find pics of that ca with the V mount???????
magnus in aus
ca18detgabby wrote:Any idea where I might find a Trust exhaust manifold for sale???????
On yahoo Japan. Do you know how to use it?
I got my Tdo5 (which was rebuilt and highflowed) trust manifold and Trust wastegate (brand new) all for $850 aus
magnus in aus
My wheels Finally came from japan,specs are17x8+1017x9+12.
Im using 25mm 4 to 5 stud spacers all around25mm wider guards on the front and rears are yet to be rolled/flared/bolt on guardNeed to put the car on level ground and see how much more i need to lower it.on with the picsfront fitment looks perfect imo
themadscientist
Pass on those. They crack badly and will likely put the turbo right where your steering shaft is.
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
SICK DUDE! i like the kit, wheels are hot too, but i love the black fronts you have in the one pic. driftastic
THATS NOT A KNIFE
ca18detgabby
03 Infiniti G35
themadscientist wrote:Pass on those. They crack badly and will likely put the turbo right where your steering shaft is.
really? thanks for the heads up
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
The car looks awesome! Glad to have some more members from Australia on here.
I too would like to run a Mitsubishi turbo, but it involves me learning to weld so I can make my own manifold.
yourmomsrps13
also ..... MID MOUNT IC FTW!!!
magnus in aus
got bored and pushed it out for a photo. Also test fitted a friends GT wing
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
ks13 wrote:Do you ever get freaked out about going into your garage and possibly getting bit by a rattlesnake when you reach where you shouldnt?
LOL, they prolly sell antidotes for 9 out of the 10 most poisonous creatures on earth at any local Gas Station, so I think he is safe.
Sick ride.
traymack1
Car: Infiniti G20(stolen), s14 240sx
Wow incredibly sick setup man.
I have a few questions,
What trim is the td05?
Was it hard mounting the intercooler/radiator setup inside the engine bay like that?
I'm very interested in Mitsubishi turbos also and I have a manifold with a t3 flange, i was told that only the td06 20g bolts up to the manifold. I wonder how hard it would be to get a td05 fitted on my manifold.
r34 gtr
^ You would need to weld a new flange on your manifold to run that mitsu turbo.
The td05 16g should be good for +/- 350hp. the 18g would put you in the 380hp range, and the td06 20g would do you about 400/420hp.
RS12Turbo
r34 gtr wrote:^ You would need to weld a new flange on your manifold to run that mitsu turbo.
I've seen adaptor plates.......garrett t25 on one side, and mitsu on the other
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
i can easily make the 16G manifolds still. i have the jig packed away on a shelf. i have two SR20 cars with them on them at the shop now, and a miata that just got one done last week. I am highly considering going back to the EVOIII and selling this EVO8 setup.
magnus in aus
traymack1 wrote:Wow incredibly sick setup man.
The td05 is a 16g, I dont no alot about it sorry as i picked it up second hand.
Its very easy to do the intercooler/rad setup. Just need to do alot of chopping. ATM im using a single 14inch thermo on a RB20det rad with no shroud and temps never pass 95 on a HOT australian day at the track. Ill attach some pics to show the setup alitle better.
I dont no alot about manifolds and what fits ect. But, My friends TRUST T67 10cm bolts upto the manifold, A td06 25g is the same as a T67 8cm.
P.S. The ca god of tuning here in Aus makes 220kw with a td05. makes 20psi by 3400rpm
magnus in aus
This is with the front choped out
test fitting the core. You can see how i have bolted it in.
And heres how the rad is mounted. I just used some steel 4-5mm thick. 50mm width and long enough to go between the two castor rod braces. Then Just drill two holes in the steel for the legs of the rad, and two holes for bolts in the braces. For the top just bend the stock ones to suit. pics up the top
Hope this helped.
meminto
Car: S13 Silvia CA18DECT
Good work magnus, I see the greddy turbo sits behind what looks like custom mounts??I guess to sit you sump higher the mounts required extending...
I am about to order a T67 25G for my second rebuild, but i wont fit mine on the low mount, however I did pickup a steampipe manifold (top mount) with 38mm wastegate from ebay uk for peanuts.. was a great find...
Ohh, and Sam is excellent, but god like, I am not too sure about that... hehe
magnus in aus
the mounts arnt custom, Theres a company here in Aus that make solid engine and gear box mounts for $150 au a pair.The sump isnt much lower then a standard item, Its been extended in width not depth.heres the seller of the mounts. Sign up and pm them if they will post over seas.http://www.nissansilvia.com/fo...92749
Modified by magnus in aus at 11:13 PM 5/4/2008
meminto
Yeah I know the mounts, yours look different in the photo thats all, it looks like it sits higher, maybe its an optical illusion... how much clearance have you got for the turbo sitting on the low mount?
I have been a member of ns.com for many years, I am also in australia, in northen nsw...
niscort
personally wouldnt waste my time spending money on those mounts. fully threaded rod means there is no isolation in the mount.. might as well use alloy blocks as there will be exactly the same amount of vibration.
magnus in aus
meminto wrote:Yeah I know the mounts, yours look different in the photo thats all, it looks like it sits higher, maybe its an optical illusion... how much clearance have you got for the turbo sitting on the low mount?
Ah coolim gold coast hinterland (tamborine mountain)
theres about a inch of clearance between engine mount and turbo
magnus in aus
bit of a updatemoved the car from tambo to its new home, got a bit stuck on the way into the garage. Car has had a complete rewire with bare essentials and microtech. It even started!!!!!!also bolted up my tdo5 and got my oil lines sorted. Trying to track down gaskets for my wastegate then i can put that on.Also painted my front guards and the rest of my uras kit black, getting some dmax 30+ guards when i have moneyHKS cams are in tooJust needs a few bits and pieces before it can be tuned.
float_6969
You don't have anything to do with a magazine called Autospeed do you?
magnus in aus
no i dont. Whys that?
