my ca18det dyno sheet
cuzan0
the 1st run was at 11 psi 206whp and 163 tq
second run 14 psi 220whp and 196 tq
sorry guys i dont have a scanner so i took a pic of it. the place i dynoed it at is http://www.bottleblownracing.com/
here are my mods stock engine internals 3" exhaust piping and muffler no catsr20det transmissionsr20det lsdT28 turbo, ca16de cams, tuned ecu by KSROM in Japan, 460cc injectors, hks evc IV, NPR fmic,walbro fuel pump,apexi air filter,apexi s-afc II, 6 puck sprung hyperclutch kitturboxs bovblitz DTT DC II turbo timer,Z32 front calipers
kevy8up
nice work.....what mods u got on that engine?
ShadowKnight006
Car: 95 240SX & 96 Altima
I believe they are listed in his sig.
kevy8up
lol well they werent there when he originally posted it damnit...lol
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
nice work, wish i had figures like that. ill see what i can do when i go back to the dyno tomorrow.
- tim
14.5drift
I am sort of new to the ca. Can cams and other head work be done to draw the power band all the way to the top? I know they can help but do they make a huge difference? Ive heard of people revving to 9k with this motor, but would it make sense since power begins to drop after 6k? When shops and stuff build race motors generally what rpm do they stop at?
boost_boy
Power starts dropping on these engines for multiple reasons. Cam profiles, valve springs, valves, knock retard, turbocharger, and ignition retard all have the ability to cause power to drop off and at different rpms. A stock CA18DET is not going to rev to 9k, but can get between 8.2k-8.5k depending on condition of the engine. And if you're doing the with the a T25 or T28, you're waisting your bearing life because those turbos are flat on their faces after about 7k rpm give or take a few hundred rpm.
Bigger turbos require more rpm to get them going which means power will come further into the powerband which results in a little more power at a higher rpm than stock. But the physical engine itself will still keep you at a specified rpm range for max power if you leave the valve train stock. CA18 valve trains float in the 8.2-8.7rpm range depending on the condition of the engine. But there is no power to be had here. Just some more rpm to help the bigger T3/T4 turbo and not the T2small ones.
I have a set of HKS camshafts in g/f's CA and the car is a bit more consistent at holding the rpm at around 8.7k rpm. Haven't gone to the dyno to see the effects of the cams because the car was wrecked not too long after I had built it. I also have a motor that is built and will be revved in the 9k-10k range as this is what was designed to do. And the beauty of the standalone is that I can toy around with where I want the timing to be retarded at or where I want the rev limiter set at. In my case it will be set 9750rpm which is the max that SDS designed my ecu to allow.
boost_boy
BTW cuzan0, nice dyno figures! Those figers puts you in the ballpark of the SR gang and possibly waxing them as well. Great job;) and I mean it.
cuzan0
yeah the numbers i puller are ok. i just wanted to see where im at and see how much more i can go. well the run went like this ok i hit 206whp at 11psi so i upped the bust at 14psi i really should have went 18psi on the 2nd run!!! i should be around 230-245whp at 18psi i asked the guy for another run but he couldnt cause there were other cars wanting to go on the dyno and i didnt have anymore money lol.... looks like all the T2 turbos drop at 5800 rpm and if you want more power on higher rpms you need a bigger turbo like a t3/t4 just like boostboy said but i think if you hit 230-245whp thats the max power you'll get,cause if your using the stock mafs it wont let you flow enough air to pass 250whp mark unless you use a standalone and remove the crappy mafs or upgrade to a z32.
oh yeah!!! hey boostboy how much is the sds system everything i would need to run my motor with a 2bar map???
boost_boy
Quote »oh yeah!!! hey boostboy how much is the sds system everything i would need to run my motor with a 2bar map???[/quote] I'd recoomend a 3 bar map sensor for a few more dollars because you may want to jack the boost up pretty high one day. A complete system like that would run you just over $1200.
cuzan0
boostboy whats your AIM or email so i can get the total price on the sds my AIM is dr bo0
boost_boy
My AIM is turb0sentra
Nismo1182
Car: Z06
cuzan0, is you afc-2 tuned?
cuzan0
yes my safc is tuned to run 460cc injectors my ecu is tuned to run 444cc injectors thats why i went out and bought the safcII
bmmfc
cuzan0, what size of exhaust are you running?
cuzan0
all my mods are on the 1st post but yeah i am running 3" piping from the down pipe all the way through the muffler
14.5drift
Do you have any 1/4 mile figures. I imagine some wheres around 14.
bmmfc
ok, just curious.
float_6969
Hey cuzan0, I'm wanting the Apex'i intake, but I didn't know if the MAFS adapter for the SR will fit the CA MAFS. If it does please let me know, as I have no air filter on it right now. Thanks!
