My CA18det build up
nissanic89
Car: 89 nissan coupe
Hey all, figured id let you know my progres on my buildmy 89 nissan 240sx coupe.I finished the swap last february and drove it around for a lil more than a year.As of march of this year my car went down for a rebuild.The compression was really low and and the motor wasnt really in best health.
The head in its unhealthiness, maybe a lil burnt valve action :-/
intake ports on head
mmm mm good
Sexy CP pistons that now reside inside the block yaaaay!!!!
Since then, I have purchased some parts and made some progress.The short block is done and all back together. Bored.020 over, decked the block, turned the crank, internally balanced rotating assembly and alot of money later VOILA!
I also just purchased a Ebay intercooler kit for an S14 with and SR20det, being that this supposed to work on ca18det cars no problem because of the design of the intake manifold.
Good ole "jdm sports" tube and fin FMICThe picture said it was bar and plate but oh well what can you do, it will work.
I have alot of work to do yet and more parts to buy. keep you updated.
Tommorrow head work will be gettin started.I will be purchasing Head studs and Jim wolf technologies valve springs.
I'm shooting for the beginning of september, not a stone cold deadline though, as some of you know deadlines just frustrate the build.
-chris
Bwana
Car: Denali
Man, that thing looked rough! Much better now
nissanic89
it saw a hard life lol, but yeah thanks I wanna do it right this time like i should have in the first place
ch187
Car: 90 CA 240sx
hey....that intercooler looks familiar. good luck on build
nissanic89
SOOOOO...Friday night at 925pm i got the car running. That same night at approximately 530 am it drove under its own power. I had to put the rear end back in and driveshaft took a lil while, that mutha ****as heavy in the early morning hours.
Buuuut any way, Lets do some catch up.Where we last left off I had found out my head was more messed up than i thought. Well I lapped the valves in myself and dissembled and re-assembled the head...The hardest thing i have ever done. I had to buy a $72 tool from tool crib and it still took me 4 hours to put it together. The lifter sits soooo far down in the head with the heavt duty jim wolf valve springs it was damn near impossible to get the keepers on the valves, a lil Vaseline and patience i didnt even now i had and volia. Awesome learning experience.Tada!!!
a lil home brew port job ;-)
some extra cheeze on this picture, putting it on the block exciting day for me
The block with a brand new copper sprayed head gasket :-)
ANNND I gots me a Engiiinne
Sooooo a few weeks went by and i got it all togetherPURPLEY GOODNESS what what
lil under engine pic of my set up
Lookin mean grrrr
Its gonna be a donut machine HEHE... Welded diff action
Ill be sure to post some vids of it running and what not soon.
_Chris_
ch187
Car: 90 CA 240sx
baller..get a new wiper motor though. they are hard to change.
nissanic89
nothing a lil black paint wont fix hehe, i was serious with my purple, im just glad to have it back it...7 months later lol
float_6969
is that short intake pipe from the MAFS to the turbo not causing you any problems? Often having it that close to the turbo can make it read falsely.
Zee
Car: 99 Chevy Cavalier
Looking real good man. Nice job
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
very nice.
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
good job..looks clean and sleek!
Jiggyfry
Good work man, its lookin hella clean and tasty.!
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
man, super sexy.
makes me want to go out and buy a CA for one of my cars...
nissanic89
Thanks every body i appreciate it, now only if i could get this thing to run right...I had it running fine then it wants to act all stupid and not stat it'll run but only off two cylinders (3 and four) its getting fuel but not spark, its really quite irritating. Any help would be awesome.
float_6969 wrote:is that short intake pipe from the MAFS to the turbo not causing you any problems? Often having it that close to the turbo can make it read falsely.
Not sure i haven't got into boost but i will keep an eye on that, i believe the rule is something like six inches away from the turbo.-chris
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
nissanic89 wrote:Thanks every body i appreciate it, now only if i could get this thing to run right...I had it running fine then it wants to act all stupid and not stat it'll run but only off two cylinders (3 and four) its getting fuel but not spark, its really quite irritating.
Had similar problem after my ca swap. Turned out my igniter was not feeding the spark signal to the coil. Igniters are all over ebay, you can get one and hopefully solve the problem.
kapower06
yeah it sounds like an igniter. Try another one and let us know how it goes for you.
float_6969
As others have said, try the ignitor first. It's the most likey. Also, I would move it away from the exhaust if possible.
Heat + Electronics = FAIL
nissanic89
Thanks for the help. Ill try that.I happen to have two q45 ignitors, clarify that those plug right up correct?
float_6969
IIRC, they work just fine.
duffman1278
Car: 89 240sx Hatch, the wildcats!
CLLLEEEAAAANNNN MOTOR FTW! very niice!
nissan240vert
Car: 1993 black 240 sx convertible
VERY NICE MOTOR BTW.
nissanic89
nissan240vert wrote:VERY NICE MOTOR BTW.
Thankyou.
Oh tried another igniter, that wasn't the problem...The problem was somehow, my gap of my plugs was way off.018 ish, i could barely get the plugs on the gapper. lol. I'm Special.
