MY CA18 is bogging, can this cause it.....
kota2240
Car: 92 Nissan Coupe W/ CA18ddet
I noticed that when im going WOT that my boost gauge only goes up to 0. My idle is at 20vac which is good. I noticed that my internal wastegate on the S15 turbo does not move. I tried getting a signal from the intake manifold and the hotpipe and nothing. Can this cause my motor to flood sometimes and bog?
Im running stock fuel pump and pressure regulator and injectors. I have no ECU codes.
rico05
Car: 1992 RMS13 w/ CA18DET
Yeah, no boost would cause a bog. Also, how are you checking the wastegate actuator? You know that it will not open unless the manifold sees boost, which does not happen unless you are under load, so unless you were on a dyno, it wouldn't move anyway.
kota2240
I had the rear on jack stands,would that matter?
burnout 180
Car: 1990 s13 180sx ca18det
no the engine has to be under load.
does anyone know why my gauge shows no vac unless i press the throttle?
datsunboy
Car: Datsuns
you could leave it on the jackstands......and get a mate to press on the brakes....that would put it under load
Bwana
Car: Denali
datsunboy wrote:you could leave it on the jackstands......and get a mate to press on the brakes....that would put it under load
and then when it falls off of the jack stands with the wheels turning he may have a chance of getting it stopped....
I don't even run a car in gear on my lift! No chances!
rico05
You need the car on a dyno or a camera under the hood while driving to see the w/g actuator do its thing.
