My ca
Tyson240sx
Car: 240sxca18det
Hey guys, its been awhile since i've signed on here. well anyways I have my ca in the shop right now getting bored out I got 84mm bore pistons from Ipp. with 8.8:1 compression. Ive also bought a front mount intercooler thats 22", 9", 3 and a quarter. Also Aem wide band, and a Aem Ebc. Im also ordering a apexi turbo timer. and a new clutch Does anyone have a Spec clutch?? how do you like it if so? ohyeah does anyone know if ca injecters are low or high impeedense?
The next things im getting are:Apexi AFC, 550cc injecters, Spec or ACT clutch, T3T4, topmount manifold from top speed, tuned ecu, 3" echaust, Apexi Exhaust tip, and a Blitz or Greddy BOV.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
the CA uses low impedence injectors (~2.2ohm iirc).
and you had better get purchasing. youll need those parts stat.
float_6969
I've got a Stage III SPEC clutch. It's fine. The pedal feel is VERY light and the engagement point is kinda high up in the pedal travel. Otherwise the clutch holds very well.
The stock CA injectors are low impedence, hence the need for a resistor pack.
Tyson240sx
Car: 240sxca18det
Hey thanx guys. Yeah i was looking at Spec stage 2. I was also looking at getting a Act clutch but when i call there to talk to them theyre not open. and they dont have any engine codes or anything to tell you what clutch you do need. Its kinda a payne in the ***. How much torque and hp do you have in your car? And what kind of boost are you running?
