biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Thu Jan 31, 2008 6:46 pm
venom is crap, I've seen many reports of people getting venom injectors that just stick open or closed or all kinds of jacked up ****.
if you have the original injectors, you might send them off to someplace to be cleaned/tested and hope they will come back OK.
Also, check the fuel pressure. If it's waaay high that'll have the same effect. Be sure it's at 36.3 relative to ambient pressure; easiest way to check is to hotwire the fuel pump relay 'on', put the key in 'on' (don't start the engine) and then check it, should be 36.3 psi.
