float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Nov 12, 2004 2:53 pm
I was gonna let you know you were stupid Tim, but you corrected yourself so I'll let it go. :biggrin But yes, it's the air regulator and generally that is the cause of cold start problems. Mine was actually stuck open and so it started great when it was cold, but wouldn't idle down below 1100rpms, regardless. I tried to unstick it, but it wouldn't budge. I finally found a replacement one that would work from a US car, (I think it's from a Sentra w/an SR) but it's gonna take some modifications to get it to work as the plug isn't the same as the CA one.
