My CA build- lots of SARD
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
I didnt know if you guys seen this pic in my build thread, but i wanted to share my clean ca build
POWERED BY MAX HMIC INSTALL/ TURBO REBUILD/ P/S/ ENGINE REBIRTH:
I ordered the s13 kit w/ s14 cold pipe since thats the closest to my CA18DET setup.all the plumbing is done/ simplified and the shortest lengths possible!
i went ahead and ordered a SR turbo outlet adapter which gave me the perfect height and angle for my hotpipe...STOKED! i also ordered a silicon 45 elbow for cold side which connects pipe to TB. I didnt even have to cut or weld any piping to fit CA.
http://www.gtfactory.jp/cms/page.php?11
- all sharp edges were sealed with door weatherstripping i had laying around...should be no vibrations ;)
- yanked headlights off and of course surface rust under brackets. i wire wheeled it off/ primed & painted flat black so its nice and clean up front.
i had to trim a lot of metal on core support to fit this, but nothing structural
i got motors seperated from headlights and trimmed bracket to fit around I/C. I had to prime and paint with my epoxy spray. i also had the support brackets sandblasted, because they looked like crap with all the overspray.
i prepped oem bumper support to make look new. it was just a gray metal finish before. i went ahead and primed and sprayed it...now its rust proof and looks good for final assembly.
- the intercooler is permanently mounted & radiator installed which fit perfect...no issues. i will not be able to run my shroud, because cold pipe blocks top rad line.
a new addition is a S14 P/S reservoir to loop into my manual rack...just to keep an eye on fluid levels. it also looks newer and cleaner than a metal s13 unit.
dropped my turbo off in Richmond during the spring to get cleaned & rebuilt...luckily i dint need anything major done.
21yrs of carbon buildup on both the rear seal cover and impeller shaft. you can see how that might cause some friction when this is trying to spin and the carbon and oil turn to syrup when the turbo gets hot.
machined polished inside compressor venturie. ( Wasabi_ Pea ) also smoothed out the compressor inlet and outlet.
i didnt want to spend 650-700 on a new Garrett nor buy a ebay turbo. sticking with factory fresh oem for a DD
picked up a new Garrett actuator from Australia.
powdercoated parts from last spring...all done in Nismo silver
high temp powdercoat on heatshield
i dont know why nissan put philips head screws on backside to hold fpr. they wouldnt budge and i started to strip one. i pulled everything out and installed the nismo fpr with new bolts that you can use a wrench on.
DSM 450CC injectors chillin & new NISMO FPR
ive been thinking my rear exhaust side valve cover has been leaking, but i found the culprit. the hose goes back into block was dryrotted and clamp was no where near the right spot... it was so wet from oil up underneath im so glad i found it though... i felt i accomplished something.
I replaced every sensor on car last year as well as getting my ecu remapped by EMANCE. car never hesitated upon startup anymore and ran s*** tons better. i also had starter & alternator rebuilt.
22630-51E02- ECU TEMP SENSOR
25080-89903- gauge temp sensor
ENGINE MODS
i went ahead and threw away my last radiator, because i had redone fan setup more than twice and spray painted it black. i wanted a fresh platform so i ordered a new stocker.
wired up thermostatic switch, because it worked so great on last setup.
replaced all my injector and IACV plugs with new BOSCH EV1 style plugs. i soldered and heatshrinked everything along with a semi wire tuck job. all my old plugs were broke and barely making connection. now everything is snapped on with dielectric grease for corrosion...should be no signal loss at all.
http://www.diyautotune.com/catalog/fuel ... -p-48.html
i moved about 2ft of engine harness behind dash. the ignitor is now inside along with resistor pack now mounted on firewall. it was up near radiator on frame rail before. everything is tight and tucked together neatly now. i picked up the rubber grommet plugs from ebay seller. i couldnt find anyone in the states that sold the right diameter.
http://myworld.ebay.com/ebaymotors/weeone_k/
no more heat! since i dont drive it in the winter anyway.
i simplified 10 coolant lines down to 2 under block. 3/4 QUEST plumbing elbows are the perfect size.
i have the 1 main line coming off near water neck which connects to back of block teed going to turbo line via 1/2 x 3/4 x 3/4 brass quest tee
used steel spacers to push AAV into stock location since i got rid of factory plumbing.
KA24E MODIFIED TB
cut off coolant ports & vac nipple underneath
JB WELDED some plastic upholstery plugs into ports
sprayed TB with VHT EPOXY paint
sprayed aluminum pulley w/ SS spray
cleaned throttle plate and inside TB
NEW gasket & TPS switch along with chrome allen head bolts for dress-up
i got this a/c foam from my hardware store to fill in gap between core support & rad.
i was having a few issues with my top coolant line being kinked, because cold pipe was right on top of it. i cut out a few sections and messed around with the bends and figured out a perfect solution. i finally got my Greddy temp adapt installed so i can keep a second gauge in car just in case factory might fail.
power is finally hooked back up into car. battery is tight, but perfect damn fit. Mobile Spec distribution block for all my hot leads. i went ahead and heat shrinked wires too look oem. i threw the pink ties in there too match lettering on fuse cover. i swear this is the cleanest setup i have ever did and the last time
SARD MAGIC BOX...help with any voltage issues. i also installed a few more grounds on exhaust side of block & transmission.
You are viewing a brand new Magic Box from Sard.
Improve idle, response, low-mid torque and drivability can be achieved with the Magic Box. In addition, static in the audio system will be reduced, power to the lights increased and a cleaner burning, more fuel-efficient engine can be realized.
Simply attach the Sard Magic Box to the car battery and stabilize the voltage going to your car's electrical system, regain lost horsepower, performance, and get better fuel economy!
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
about time you posted this up in here!
love it
float_6969
Nice. More pics please!
meminto
Car: S13 Silvia CA18DECT
Nice and clean.... good work...
themadscientist
I want to rub my junk on your car.
Virginia boy too, holding it down. Virginia is for boost lovers biatches!
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
themadscientist wrote:I want to rub my junk on your car.
LOL
Clean indeed. Awesome job.
splintercell
EXHAUST MODS & PARTS:
CIRCUIT SPORTS DOWNPIPE & ELBOW
CIRCUIT SPORTS URETHANE EXHAUST HANGERS
FR SPORT COPPER NUTS & GASKETS
WEDSPORT MUFFLER GROUND
SARD TCV
APEXI N1 Titanium Gold muffler
CUSTOM 3" EXHAUST
finally got my Circuit Sports SR ELBOW & DOWNPIPE INSTALLED. i waited 2 months for them to get back in stock. got the SARD TCV reinstalled along with my WEDSPORT muffler ground. i mounted that to transmission mount out of the way...before it hung a little so it had animal air and dried up blood when i skimmed over a few roadkill :D
of course my new downpipe is 6" shorter than the fabbed up one i had...so rear section doesnt mate up too SARD unit...FML! when i get car back on road ill drive a block to a garage...see if they can weld a section in.
one great thing about new downpipe is that it hugs the floor pan better and not as low as my other setup.
The Weds Muffler Earthing Grounding System 40cm is a universal 'Earthing/Grounding System' for just about any vehicle looking for a smoother and more efficient muffler.
The kit comes with 40cm of high quality grounding line.
With proper grounding, improved idle, response, low-mid torque and acceleration can be achieved by enhancing the performance of electronics.
Here is what Weds has to say about their product:
What is Muffler Grounding?
-Static electricity is led away from the muffler.
-The internal resistance in the muffler is decreased.
-Rust prevention. Due to the removal of static electricity.
-The accelerator response improves.
-A low-speed torque improves.
-The audio noise is decreased.
OLDER PICS, but thats what it looks like installed
Ca_Silvia
B-E-AUTIFUL car man! But did you paint your alternator belt orange?
DALAZ_68
Car: 90' 240sx CA18det
i think its red
splintercell
Ca_Silvia wrote:B-E-AUTIFUL car man! But did you paint your alternator belt orange?
lol, its power enterprise...it comes like that.
DRIVETRAIN MODS & INSTALL:
TRANS:
- AGENCY POWER S/S BRAIDED CLUTCH LINE
- NISMO SLAVE CYLINDER
- NISMO TRANS MOUNT
- CUSCO BRASS SHIFTER BUSHING
- REDLINE GEAR OIL
- COMPETITION CLUTCH STAGE 2
- RESURFACED OEM FLYWHEEL
- DRIVESHAFT SHOP 1PC STEEL
INFINITI J30 DIFF:
- STANCE ALUMINUM BUSHINGS
- all new parts from Nissan:
- diff gasket: 38320-40F02
- diff cover bolts: 38321-U300A
- bolt-differential: 55424-33P00 ( longer bolts needed to hold diff to subframe )
- breather: 38322-P6400
http://www.ballerbolts.com
http://ballerbolts.com/240sx-fastener-kits.html
- 12.9 bolts for axles & driveshaft...didnt want to take any chances with old bolts.
- took diff cover off so i can strip all the paint off and polish it out then clear coat it. i would think the fins would do there job more efficient without layers of paint.
- clear coated J30 diff cover and hubs w/ Duplicolor high temp clear engine enamel.
- recoated diff housing w/ VHT epoxy spray
boost_boy
It is is definitely one of the more nicer CA powered S13s I've seen. Beautiful car man and please don't sell your engine. If you need more power and feel you're about to get ripped off, ship the car to me and I'll get some power out of that motor . Other than that, take care of the car, the motor and continue to represent.
Dee
BigMACKenzie
Car: 1993 Nissan 240SX convertible
that is nothing short of beautiful man. srsly I cried a little. then I saw it was in VA and I cried a little more and mapquested a road trip so I can dry hump your car. Mmmmmmm tail pipe surprise sex ^^ but on the real, this car is super clean and super tasty. I give you 10/10 on effort and execution. Good form sir.
ca18detgabby
03 Infiniti G35
boost_boy wrote:It is is definitely one of the more nicer CA powered S13s I've seen. Beautiful car man and please don't sell your engine. If you need more power and feel you're about to get ripped-off, ship the car to me and I'll get some power out of that motor . Other than that, take care of the car, the motor and continue to represent.
Dee
he is getting an SR turbo..... not an SR engine.......
splintercell
boost_boy wrote:It is is definitely one of the more nicer CA powered S13s I've seen. Beautiful car man and please don't sell your engine. You need more power and you're about to get ripped off, ship the car to me and I'll get ome ower out of that motor. Other than that, take care of the car, the motor and continue to represent.
Dee
THANKS DEE!! im def not selling the motor just installing an SR T25 TURBO. nothing major...run a few more lbs boost. im all about reliability anymore.
BigMACKenzie wrote:that is nothing short of beautiful man. srsly I cried a little. then I saw it was in VA and I cried a little more and mapquested a road trip so I can dry hump your car. Mmmmmmm tail pipe surprise sex ^^ but on the real, this car is super clean and super tasty. I give you 10/10 on effort and execution. Good form sir.
lol, let me know whenever...just stay away from the tailpipe
ca18detgabby wrote:he is getting an SR turbo..... not an SR engine.......
thanks GABBY
BigMACKenzie
stay away? thats where im going first
ca18detgabby
03 Infiniti G35
BigMACKenzie wrote:stay away? thats where im going first
I take it you know this guy?
http://i130.photobucket.com/al...e.jpg
PS I will keep the picture to a link as to not totally ruin the thread
splintercell
haha
ca18detgabby
03 Infiniti G35
splintercell wrote:
haha
I told you TIM was famous
BigMACKenzie
a beetle? no way thats like going home with the chunky hippy chick, this is the shmexy raver grrl lol
ch187
Car: 90 CA 240sx
sr t25? WEAKSAUCE.
i have a brand new s15 gt28r with your name written all over it.
splintercell
ch187 wrote:sr t25? WEAKSAUCE.
yeah, yeah. i didnt have 800 to throw into a new turbo so i picked up a SR T25 for $100. no shaft play and spins freely...just need to clean it up.
BigMACKenzie
is the gt28r potentially up for grabs?
ch187
Car: 90 CA 240sx
why yes it is sir. to eliminate thread jacking i'll email you
splintercell
i havent updated in awhile, but i posted some newer pics in first post
i figured since the motor was 20 yrs old it was time to refresh some stuff. i yanked everything out of engine bay except block. i replaced some of the old rad lines under manifold and oil line off valvecover that runs down by oil filter...it was leaking, because it was so damn hard.
i had alternator and starter rebuilt which cost $95.00 a piece
i went ahead and had all these parts powdercoated to make it easier to clean and look new
picked up a oem header heat shield from a nico member and radiator shroud from DEE!! THANKS
replaced clamps with torque clamps on radiator hose, because they dont bite into silicone.
emance chipped ecu for all my upgrades...got rid of safc
all new sensors/ aav/ plugs/ threw a ground on exhaust side of block and wedsport ground on SARD TCV
i also replaced all cam cover bolts with chrome allen heads and eveywhere else w/ ss bolts
ragenasian
Car: AE86 w/CA18DET
Hey splinter I HATE YOU!!!
Beautiful car man. I need to hit you up for some goodies
meminto
Very nice, I like the bay work...
This vehicle is on my list of favorites ...
splintercell
ragenasian wrote:Hey splinter I HATE YOU!!!
anytime i still need too oRder that alarm for you
meminto wrote:Very nice, I like the bay work...
thanks man...i really love this little motor and i think it shows with all my attention to detail. its just awesome to see people at shows try to guess what kind of motor it is. 15% of them actually know what it is...then want to give me a bunch of s*** on my why i picked this motor. i dont understand why people hate on this motor so much
Modified by splintercell at 9:21 PM 6/22/2009
boost_boy
Hate is free, so let 'em enjoy .
Dee
ca18detgabby
03 Infiniti G35
boost_boy wrote:Hate is free, so let 'em enjoy .
Dee
Ps you manage 15% know what a CA is. I would be shocked with 5%...... even in a group of 240 owners.
splintercell
true...i could be giving them too much credit
