huguetguy »
https://forums.nicoclub.com/huguetguy-u2799.html
Wed Mar 19, 2003 8:02 am
This is my dyno chart showing my somewhat baseline runs (before headers, after headers) and then the built engine that a crappy shop here in Richmond VA did for me...I'm so sick at the weak performance of this engine, but it's an enigma to me why it would be putting out such low numbers! and now the shop has gone out of business and I'm stuck with their crappy job...
I did do a leakdown test and Cylinder #1 is leaking 10%, the others are 2%, but I don't think that's enough to warrant this kind of power loss.
The KA24DE engine was from a 1996, the intake manifold from my 91 s13 was used with all the electronics. This is my setup:
10.5:1 JE pistonstotal seal rings (now I hear all the bad reports after the fact)0.040 overborerebuilt engine internals (polished crankshaft, new oem valve springs, etc.)lightened flywheelJWT camsJWT ecuengine set at 20 degrees BTDChotshot headers (old version)short injen intakeremoved EGR/AIV2.5" exhaust
I thought that perhaps the cams were causing the massive torque loss, but then I read that they're not supposed to lose anything low-end, so I'm not sure what else it could be...
I've been talking to some guys here in Richmond at Performance Direct, but they deal mainly with Honda, so this is not their specialty...what are some Nissan shops in the Richmond and surrounding areas?
Any suggestions people? could the 10% leakage in cylinder #1 cause this much power loss?
Dave
