So that is my progress so far. Plan is to strip fix rust/crap spots, paint(black) and get going on some other things.
Evan
F*** ME! That's not bad at all. Good job.Scotty41 wrote:Well i got ignition already just need doors and i talked to a local lock smith and said he could do it all for me to be keyed to ignition for 50 bucks. See how it goes and thanks
it's not that hard...as someone already said, take the two 12mm bolts out of the upper steering column and it will lower down enough to take it off. If your still having problems, take off the two 12mm nuts closer to the firewall and it will set the steering wheel on the floor. If you can't get it out then....ummm, quit messing with it.DriftBoy07 wrote:I f***ING HATE THAT PLASTIC TRIM AROUND THE GAUGE CLUSTER.
Mine is off and Ill never put it back on, took me 2 weeks to get the damn thing off w/o cracking it.
