rotorimp wrote: With the size of injectors that your using you must be going to make some serious power--I would also recommend some ARP Main studs and get everything balanced. With the cometic Head gasket get the block decked flat and the head cut flat as well or you with have problems sealing--metal head gaskets NEED really flat surfaces to seal well (also you will have to take the appropriate amount of material off of the timing chain covers as well. good luck!
I am only shooting for about 400whp, and some really good KA-T guys I know said my main studs should be fine. As far at the cometic HG goes, I am having a shop who specializes in KA work fit the head with the gasket, and the boring work for me. I am paying a pretty penny to have all this stuff done correctly.
