my buddy TT'd the nismo.
Nissan 350z / Nissan 370z general community discussion forum
dasoupdude
Car: 2005 Nissan 350Z
um tada?
Konartis
Car: 03' nissan 350z sold <--- 91' 240sx sold
thats hot
dasoupdude
Konartis wrote:thats hot
..tter than the sun.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
not the first but still an excellent choice
ldstang50
thats awesome. almost makes me want to say they should have come like that from the factory
Initial_R90
Car: 2003 Zo6 Corvette RIP BLOWN up on the dyno
2003 Evo VIII
aps kit?
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
sweet now get some vids of it so we can hear it
JETPILOT
That's the GT Motorsports twin turbo kit.
Mr. Z33
Car: 2003 Pearl White 350Z
That kit looks amazing! Hurry and get some videos up
dasoupdude
Initial_R90 wrote:aps kit?
JETPILOT wrote:That's the GT Motorsports twin turbo kit.
Correct.
xjmxstac
Car: 2003 nissan 350z track edition
Post the results from the dyno!
dasoupdude
Indeed I will, as soon as he does though. which i hope is soon, i never knew HR's could put out to nearly 500hp with hardly anything done internally. I might want to TT the good ol' zee soon too. I'll be happy happy with 350whp.
JETPILOT
What size turbo's did he order and which computer did your friend end up going with?
dasoupdude
JETPILOT wrote:What size turbo's did he order and which computer did your friend end up going with?
I know the turbos are 2 bb GT28rs. Not too sure bout the comp, i'll ask when i get a chance.
ah, its the stock ecu with a reflash done by Osiris.
Modified by Dasoupdude at 9:15 PM 5/6/2009
JETPILOT
I have the same turbo kit also with the GT28RS turbo's for the DE motor.
Respect to your friend for installing this kit with the motor in the car. I took my motor out to install the kit. I couldn't imagine doing it in the car. I also used a lift. Doing it on jackstands msut have sucked!
My car is in Riviera Beach right now getting tuned.
dasoupdude
ah, hp logic!
JETPILOT
Japtrix
evildky
06 Nissan 350Z GT
what engine managment systems do you guys use that requires you to send the car off for tuning? I think I'd select a system a bit mroe user friendly
dasoupdude
JETPILOT wrote:Japtrix
How have they been doing lately, Some guy i talked to had said they messed up tuning his car and a few others.
Its this guy, g35tt http://www.youtube.com/user/wizza1337
Z32 TwinZ
Car: 1991 300zx TT
Pretty quick, but his exhaust sounds disgusting...
JETPILOT
evildky wrote:what engine managment systems do you guys use that requires you to send the car off for tuning? I think I'd select a system a bit mroe user friendly
The best engine managment out there for the Z besides a $7000 MOTEC is the HKS F-CON. HKS locks their ECU. HKS dealers are the only one with the key.
I used to run the UTEC, but it isn't a perfect solution especially if you are making more than 500whp. The idle with the UTEC is horrible. The resolution is poor and has to interpolate temperature.
The FCON is much more capable and is a stand alone and removes the OEM computer from all ignition and fuel control. The UTEC only switches on after it senses boost.
Modified by JETPILOT at 2:24 PM 5/7/2009
JETPILOT
I believe the person you are talking about JTrain was tuned at Japtrix by Roger C. who has since left and has started Horespower Logic. I have no issues with the new Japtrix tuning my car. I am close to Sam @ GT Motorsports and he is recomending the new Japtrix. Sam wouldn't recomend them to me if they weren't the best.
In addition the new japtrix is an HKS dealer and tuner.If something goes wrong there is only one person to blame. I'm not worried.
Modified by JETPILOT at 1:08 PM 5/7/2009
evildky
06 Nissan 350Z GT
The FCO nis ,uch more capable and is a standaloen and removes the OEM computer from all ignition and fuel control. The UTEC only switches on after it senses boost.
yeah I thought the utec was a piggyback, and I'm no fan of piggybacks, I know the Z33 is drive by wire and has variable valve timing but otherwise it's the same as any engine, and the variable valve timing is an easy work around with a window switch, I know greedy has a system compatible with the VQ, but any system with wideband capable and has datalogging makes for quick and easy fuel tuning, timing requires a dyno to get perfect but once the fuel is done it doesn't take much dyno time to get the timing worked out, me I <3 megasquirt but as far as I knwo no one has written code for drive by wire, but it's open source code so it's only a matter of time
azS15
Car: S15
The kit is sexy man. Need to get some vids up so we can hear it now. Seeing is ok but the sound is ten times better!
Return to “350z / 370z Discussion”
