I'll bet that one of your rubber brake-lines have ruptured like mine did....
"Here is the brake line that popped... the break occurred just below the metal crimp and just before I got on the highway (phew). My foot sank right to the floor and I almost ran right through the light...It was my fault for not changing them sooner...Better pic below this one...."
Fill up the fluid, turn on the car, push the brake HARD all the way to the floor, hold and have someone inspect. This shouldn't be hard to spot... that much fluid has to show up somewhere. Also, check calipers....a piston seal may be bad in which case you should have fluid running down the inside of your rim.
See links...
zerothread?id=110515
zerothread?id=114717
